Nikonhacker
paaton
Nikonhacker
Viesti Kirjoittaja paaton »
No nyt on jotain tapahtumassa nikoninkin puolella.
http://www.diyphotography.net/hacked-ni ... e-liveview
http://nikonhacker.com/
No tuonhan kyllä tiesi jo aiemminkin. Nikonilla on loistava tapa tehdä halvempia runkoja. Napsutellaan vain softalla ominaisuuksia pois riittävän paljon.
NH tells that the feature was there all along, only it was disabled in software and needed a small technical tap to be unlocked.
Here is a short explanation coming from coderat, a member of NH forums, suggesting that mode D7000 features can be brought into the D5100 :
"I guess the reason is pretty obvious: D5100 and D7000 firmwares are built from same source code. So most things from D7000 are inside D5100, perhaps all (I expect also DOF-preview function be there, but no button to activate). Because we see for example everywhere in a cycle work with SDHC Channel 0 and Channel 1 in D5100, but only channel 0 is enabled. Same sensor, same TX chip, and it is much easier to keep firmware almost same because you save a lot of time for development and testing."
