Nikon Zf, uusi retropeilitön
https://nikonrumors.com/2023/08/18/brea ... i7gk-EYT3s
Huhutut ominaisuudet
IBIS
-Max. shutter: 1/8000s
-Shutter selection options: Manual /Electronic/Auto
-Black camera body
-24.4 MP BSI-CMOS sensor
-Weight: 700g (inc. battery, the Z5 is 590g, the Z6II is 615g )
-Dimensions: 144mm x 101mm
-Up to 30fps (JPG/HEIF)
-4k 60 video
-USB C PD (fast-charging technology based on the USB-C standard)
-ISO 100-64,000 (for comparison the Z6II ISO range is 100-51,200)
-EN-EL15 battery
-Dual memory card slots (SD+MicroSD) – this is probably why the first reports came out with only one memory card slot, the second slot could be hidden and be used just like the internal memory on some cameras
-Pixel Shift: new high-res mode will be implemented for the first time in a Nikon mirrorless camera
-August-September announcement, shipment before the end of 2023
-Improved autofocus compared to Z5/Z6II
-A few different lens kits/bundles will be available in the $2,000-$2,500 price range
-Price for body only: $1,999
-One of the bundles will be with the Nikkor Z 40mm f/2 (SE) lens (no new lens will be introduced with the Zf)
-Very similar (but improved) design/layout from the Nikon Zfc
-Small LCD screen on top for aperture display
-New 3rd function on the sub lever of the shutter speed dial (besides photo/video) for B&W mode (B&W/Photo/Movie)
-Has a little grip/bump like the Nikon Df (see the mockup pictures)
-Better build quality compared to the Nikon Zfc
-Fully articulating screen
IBIS
-Black camera body
-4k 60 video
-EN-EL15 battery
Re: Nikon Zf, uusi retropeilitön
Tämähän näyttää varsin mainiolta kameralta jos speksit pitää paikkansa. Voisi jopa miettiä kakkosrungoksi/reissukameraksi. Mielenkiinnolla odotan arvosteluja miten hyvin pixel sift on toteutettu.
Nyt o aivan pakko raapia päätä. Siis kuinka pahasti Nikonin laiva seilaa kun laitetaan superresoluutio ensin siihen mikä vähiten sellaista kaipaa? Mitä hemmettiä? Eikö ny mikään kello soi Z8/9 -akselilla?
Sääli, että kuvien perusteella joystick näyttää puuttuvan tyystin..
On se sääli. Jos saisi edes peilillisen version..
Jää nähtäväksi onko tässä tuota ominaisuutta. Huhuja vasta.
Oispa tää ollut peilikamera. Olisi sopinut muuten retroon lookkiin (ja tuohon pentaprisma-kuuppaan).
https://imaging.nikon.com/imaging/lineu ... rless/z_f/
Jaa, niin vastaus ylläolevaan: " And, for the first time ever, the Nikon Z f allows for pixel shift in post-processing, for either 4, 8, 16, or 32 shots to be combined in post for up to 96 megapixels. "
https://www.adorama.com/alc/nikon-zf-camera/
Siis Nikon todellakin seilaa kuutamolla. Ei hemmetti superresoluutio terassikameraan.
Ehkä se on vielä sen verran kokeiluasteella, että testaavat sitä vähemmän Pro mallissa?
Mutta hyvä, että tulee.
Väriviuhka on lainattu Pentaxilta
Fujihan tehnyt peilittömiä retroja jo vuosikausia sitten...
Nuohan tehdään editissä, ei kamerassa. Eli sama ominaisuus löytänee tiensä muihinkin softapäivityksellä. Sehän vain shiftaa kennoa ja ottaa uuden kuvan.
Miedosti tuo voisi kiinnostaa. Mulla on vielä parit M42-lasit hyllyssä. Tosin 50-millinen ja 135-millinen. 35-millinen olisi tuohon kuin nenä päähän. 1.2 valovoimainen.
Etsimeen kun saisi vielä leikkokuvasimulaattorin.
Ja runko kromi/musta. Ainoa oikea vaihtoehto.
Jep shiftaa kyllä. Mut mitä sen jälkeen tapahtuu on yleensä hiusten repimistä mikäli ulkona kuvaa. Tarttis olla Panasonic tyyppinen lähestymistapa missä tehdään liikekorjaus (AI peliin) ja yks RAW pihalle missä kaikki aihiot sisällä (tämä Pentaksilla).
Toi menee naurettavuuksiin tuo palapelin palojen arkistointi. Sanoisin et liian vähän ja liian myöhään - hifistelijät menetettiin jo Z8/9 osalta muihin leireihin. GFX100 tarjoaa jo yhdellä ruudulla melkein 45MP 4x superresoluutiomoodin verran detailia.
Joo, no tuossa aletaan lähestymään sitä pistettä, että voidaan kysyä mikä on valokuva. Toki valokuvaa on kaikenlaista, lähtien hirvenraadosta messinkilevyn päällä, mutta noin perinteisessä mielessä jos AI luo kuvan, niin sitten ei ole kuin hetki, kun siihen saa kanootin ja auringonlaskun palmupuilla samaan kuvaan sadan miljardin pikselin tarkkuudella.
Mut joo, aika näyttää myykö tuo. Tuskin tuosta kuitenkaan mitään voluumimallia tulee. Ja onhan tuo tekniikan osalta hieman miljoonalaatikon tonkimista: kenno z6:sta ja prossu z8:sta.
Tarkoitin et AI hoitaa se liikekorjauksen esim. jos lehti heiluu ja sitä ei voida päätellä muista osaruuduista. Panasonic koittaa laskea raudalla sen korjauksen (jos päällä) niistä osaruuduista mikä parhaiten sopii. Se toimii aika hienosti sekin. Mut kun mitään korjausta ei tehdä, joudut itse tonkimaan sieltä osaruutukasasta sopivan ruudun ja maskaamaan sen käsipelillä. Toista sama n-kertaa per kuva niin alkaa kasetti leviämään. Jotkin konvertterit, esim. RawTherapee osaavat käyttää RAW-containerin sisältä osaruutuja liikekorjauksessa, mutta Adobe Camera RAW vaikkapa ei ymmärrä tuollaisesta korjauksesta mitään vaikka muuten osaakin superresoluutio-RAWia käsitellä.
Tää uusi ZF on ihan hyvän oloinen vehje. Ei samanlaista serriä, mitä esim Sonyn 2010-luvun paneeleilla ja
yhdellä korttipaikalla varustetut ihmeet.
Lanseerattiin varmaan tämä ensin, että saadaan kiireisimmät hätähousut ostamaan tämä sen sijaan, että myöhemmin julkaistava Z6III
johon tod.näk tulee 33mpix kenno.
Ylipäätään Nikonista on kasvamassa ihan hyvä järjestelmä kun siihen löytyy tamronin vahat budjettilasit, sekä kolmansienkin
linssejä.
Tilanne surullisen Canonin suhteen toki muuttuu jos sinne leiriin julkaistaan budjetti 200-600 f5.6-6.3 lasi.
Mutta ilmeisesti sinne on tulossa jotain 200-600 f8.0 tms hirvitystä. Nykyisellään Canonin lähes ainoa valtti on sen hyvä automaattitarkennus.
linssejä.
Jaa-a... en tiä. Kun näitä Nikoneita nyt vertaa, niin onhan tuo hieman kallis. EVF:kin paskottu verrattuna noihin kahteen muuhun.
https://www.bhphotovideo.com/c/compare/ ... 788062-REG
Vai surullisen... Ketterä RF 100-500 kyykyttää nämä halkomaiset (150)200-600:t aivan kaikessa:
- 100 mm:llä voi kuvata esim. tiukkoja maisemia, 200 mm on niille liikaa.
- 90 cm @ 500 mm:llä voi kuvata esim. ötököitä ja yksityiskohtia suoraan alaspäin, 2.5 m @ 600 mm:llä ei voi.
- 205 cm mahtuu kompaktiin olkalaukkuun pystyyn, 320 cm vaatii ison repun > https://camerasize.com/compact/#851.910,870.830,ha,t
- 1350 gr etupäästään kevyt ja lyhyt tele on nopeampi ja varmempi käsiteltävä, toisin kuin 2120 gr etupainoinen ja pitkä tele.
- 77 mm suotimet sopivat useimpiin muihinkin zoomeihin, 95 mm ei sovi.
Aikoinaan vaihdoin A7R3 + FE 200-600 > R5 + RF 100-500 settiin, juuri edellä mainituiden syiden sekä Canonin maagisen seurantatarkennuksen takia. En ole katunut sekuntiakaan, kuvien monipuolisuus ja laatu pomppasi C:n myötä aivan toiselle tasolle. Mut jokainen valitkoon romunsa tarpeidensa mukaan...
No, kyllä tässä uudessa "retrossa" haisee vieläkin vanha Df. Ristisiitos tekniikan suhteen, totaalista SERriä (EVF) ja lopulta iso läimäys hires-nikonistien poskelle (superresoluutio museokameraan).
Tässä käy kuten Df:lle. Ostajia alkuun kolme ja lopulta Rahala tuuhioi "vahingossa" jonku 1500€ diilin mikä romuttaa iäksi vehkeen hinnan Suomessa.
