Sony A7IV
Sony A7IV
Yes. Nyt alkaa tapahtumaan!! Julkaisu kohta käsillä;
https://www.sonyalpharumors.com/
https://www.sonyalpharumors.com/a7-4-4k ... -s35-mode/
The A7IV can record 4k 60p: It will be oversampled from 4.8k s35 mode and 10bit 4:2:2. I am getting more info every hour now so stay tuned!
Sony A7IV rumored specs:
launch on October 21 (if chip supply permits this)
Newly developed 33MP sensor
15 stops of DR
3.69m dot EVF and LCD is improved too (1.44m dot???)
4k30 video is oversampled from 7K
4k 60p will be oversampled from 4.8k s35 mode and 10bit 4:2:2
5.5 stops of IBIS (+ AS)
Same A7sIII body design and same heatsink system.
Full size HDMi
Fully articulating LCD screen
UHS-II SD-cards and CF Xpress cards
Same new Sony menu system of the A7sIII
I am still not sure about this but price might be around $2,499???
15 stops of DR
Full size HDMi
Re: Sony A7IV
Joo, ja ilmeisesti Sony 70-200/2.8 mark II julkaistaan viikkoa aikaisemmin.
Tärkeitä julkaisuja molemmat. Normaali teknisten parannusten sijasta minua melkein enemmän kiinnostaa A7IV mallin softa. Onko tullut uusia kuvausohjelmia, kuten focus stacking, monivalotuksia jne...
Re: Sony A7IV
Tänään Sony ilmeisesti julkaisee virallisen A7IV teaserin...
https://alphauniverse.com/
https://www.sony.com/en/
https://electronics.sony.com/
Re: Sony A7IV
sieltähän se tiiseri putkahti!
https://www.youtube.com/watch?v=zreZpSXWtiA
eikkäs 21. päivä on laukaisu!
Dpreview;
https://www.dpreview.com/news/514986170 ... ement-date
As tends to be the case with many of these YouTube premiere teasers, Sony doesn’t reveal any details about the camera in the video’s description or in the placeholder image. That is, aside from the confirmation it will be a Sony Alpha camera system and its announcement date.
However, if you look a little deeper and pull the metadata tags from the video, which YouTube uses for its integrated search engine, we get the following list:
'ILCE-7M4 , A7M4 , Alpha 7 , Alpha7 , Sony A7 IV , Sony a7 IV , Sony α7 IV , Sony A7 iv , Sony a7 iv , Sony alpha , Sony α , mirrorless , Sony E-mount camera , full frame camera , 4K , Eye AF , Animal Eye AF , AF , Eye AF movies , field camera , pro camera , silent shutter , FTP , 4K60p , Eye AF birds , camera for movies , 10fps , 33MP , BIONZ XR , 10-bit 4:2:2 HLG , All-I XAVC S-I , S-Cinetone , S-log3 , S&Q dial , vari-angle , gimbal , 5GHz Wi-Fi , USB 10Gbps , live streaming , Creative Look , 15+ stops dynamic range'
Eli tägeissä löytyykin jo ominiauuslistaa;
Sony a7 IV
- uusi 33mp kinokenno
- 4K60p
- 10-bit 4:2:2 HLG , All-I XAVC S-I
- 5GHz Wi-Fi
- USB 10Gbps
- 15+ stops dynamic range
Dpreview;
Sony a7 IV
- 4K60p
- 5GHz Wi-Fi
- USB 10Gbps
Re: Sony A7IV
No nyt! Alkaa pukkaan kyllä hyvää kuvaa.
Re: Sony A7IV
No totta munassa!!
lissää;
BIONZ XR processor
10fps
830 JPG+RAW buffer
15 stops of DR
Up to 204800 ISO (huhujen mukaan yhtä hyvä kuin tavanomaisissa kinojärkissä ISO 102400!!)
Re: Sony A7IV
Joo, en tiedä, mutta alkaa kiinnostamaan minuakin.
Uuden sukupolven 33mp kinokenno saattaisi riittää (42mp tottuneelle), varsinkin kun oletettavasti mukana myös pixel shift (jolla saa 132mp resot). Kääntyvä näyttö, ja nykyaikaista AF vauhtia. Vielä jos olisivat saaneet lisäominaisuuksiin uusia ohjelmia kuten focus stacking niin melko varmasti löytäisi tiensä pukinkonttiin...
Re: Sony A7IV
Höpö höpö. Tossa uusimpien Sonyjen DR:t > https://www.photonstophotos.net/Charts/ ... 9M2(APS-C) .
Re: Sony A7IV
So? Siinä on sonyjen ja muidenkin kameroiden DR listaa.elmar kirjoitti: ↑Loka 19, 2021 21 : 07Höpö höpö. Tossa uusimpien Sonyjen DR:t > https://www.photonstophotos.net/Charts/ ... 9M2(APS-C) .
Mutta nyt puhutaan tästä uudesta tulevasta mallista. En tiedä mistä ovat 15+ dynrangen repineet, mutta jos se edes olis lähellä, niin puhuttaisiin uudesta selkeästä kehitysaskeleesta! Eihän sitä tiedä, on kuitenkin aivan uusi kennotyyppi.
Re: Sony A7IV
Valmistajat ja DxO paasaavat kennon teoreettisesta DR:stä, kuvan todellinen DR (photographic DR) on jotain aivan muuta. Kolmen stopin hyppy on höpöhöpöä, rajuimmat muutokset ovat olleet n. 1/2 stoppia, jos sitäkään.
Re: Sony A7IV
Kyllä sen tietää, että nämä kaikki tulevat noudattamaan luonnonlakeja. Ainoa tapa saada 15 aukon dynamiikka on laittaa kennolle erilaisia pikseleitä. Jos tekevät niin, toivottavasti muistavat mainita rehellisesti miten se vaikuttaa sitten resoluutioon.
Nykyisten kennojen ylisuuri resoluutio mahdollistaisi tuollaiset temput. Kyse on vain siitä, että megapikselit, jonka merkityksen apinakin tajuaa, ovat myyvempi speksi kuin dynaaminen alue.
Re: Sony A7IV
Mielenkiintoista nähdä miten tuohon 15 stopin dynamiikkaan on päästy! (oli se sitten teoreettinen tai sävytestillä/photographic DR saatu)
Onko Canon myynyt käyttöoikeuden patenttiinsa? ... ja saanut Sonyltä jotain tarvitsemaansa?
Canonin systeemi, joka myös speksaa 15-bitin dynamiikan, on patentoitu.
Siinähän yksi senseli on jaettu kahtia (kaksi valodiodia peittää senselin alueen), ja kumpaankin tulee valo saman Bayer-suodattimen elementin ja mikrolinssin kautta. Siis tarkoitan tätä (jota on vasta käytetty Canonin videokameroissa):
Kuva: Tämä ottaa yhdellä valotuksella HDR-kuvan senseliin tulevasta valosta. Senselien määrä vastaa siten myös ilmoitettuja megapikseleitä.
Tokihan tuon saman elektroniikan voi toteuttaa kahdella senselillä ... vai tuleeko senselien etäisyydestä ja Bayer-suodattimesta tällöin ongelma.
Viimeksi muokannut jaava, Loka 20, 2021 14 : 19. Yhteensä muokattu 3 kertaa.
Re: Sony A7IV
Tuossa edellisen viestin kuvan mukaisen senselin High Dynamic Range (HDR) toimintaan vaikuttaa:
- Senselin kahden valodiodin (A ja B) pinta-alojen suhde (pinta-ala vaikuttaa fotonien-keräysnopeuteen)
- Kummankin diodin lukuelektroniikan kapasitanssien (C1, C2) suhde (kapasitanssi vaikuttaa lukuvahvistukseen)
- Yhdistäjäkomponentin algoritmin rakenne (kuvan esimerkkki-algoritmi antaa senseli luettaessa 4 * V1 + V2. Kenno suorittaa sisäisesti kaksi lukua, joilla se saa valodiodien A ja B lukujännitteet V1 ja V2 digitaalimuotoisina).
Tämä on aivan sama periaate (per senseli), kuin tehtäessä kahdesta kuvasta Lightroom:ssa HDR-kuva.
Re: Sony A7IV
O.M.G.!!
Ensimmäinen paparazin vuotama bikinikuva tästä kaunokaisesta!!
Voi että, miten sitä malttaa huomiseen???
Eikä tässä vielä kaikki.
Uutta pukkaa urakalla;
https://www.sonyalpharumors.com/nokishi ... red-about/
kaksi uutta salamaa + joku major Sony announcement lisää 6 viikon sisällä, mahdollisesti A6xxx malli. Ja sitten vielä se 24-70/2.8 MARKII
Täytynee hakea hetimiten paketti Tenaa varmuuden vuoksi, tiedä miten tässä vielä eritteet lentää kun kliimaksi etenee vääjäämättä kohti huipennustaan!!
Re: Sony A7IV
Odotitko, että sen ulkonäkö poikkeaisi jotenkin tuosta? Tuo on niin peruskamera kuin olla ja voi.
Olen tavallaan kateellinen tuosta kyvystä innostua teknisistä leluista noin paljon. Minä menetin sen jo suunnilleen siinä vaiheessa, kun hommasin Amigaan 50 MHz:n 68030 turbokortin. Silloin ei ollut tavalliselle kuolevaiselle tarkoitettuja digikameroita olemassakaan.Täytynee hakea hetimiten paketti Tenaa varmuuden vuoksi, tiedä miten tässä vielä eritteet lentää kun kliimaksi etenee vääjäämättä kohti huipennustaan!!
Re: Sony A7IV
Popparit esille? Draaman kaari lienee huikea aallon harjalta pohjalle, ja ehkä takaisin harjalle...Huomenna se mahdollisesti nähdään...
Re: Sony A7IV
eieijeijeijei. Gyllä tässä surffataan aallon harjalla niin kauan kun aaltoja riittää!! Ja sitten kun ollaan takas rannalla niin haetaan puoli alastomalta Pamela Andersonilta kylmä mojito, ja jatketaan uusille aalloille!! Pamela jää pikkarit märkänä hurramaan biitsille!! oijoijoi,tzonysonyyyy.
Re: Sony A7IV
Showreel:
https://vimeo.com/814152881
Re: Sony A7IV
Melko hätäseen kävi delete-nappi.
