8256 x 5504px resolution that confirms a 45MP stacked sensor (it is interesting to note that Canon decided to go with a 24MP sensor for their R3 camera).
The Z9 will be capable of up to 120 fps in a lower res file size (6Mb I think). Some reports even indicated 160 fps!
Built-in GPS – probably GNSS (Global Navigation Satellite System).
The Z9 will use the same battery as D6. There will be also a new 18-type battery (EN-EL18x) that can be charged by the camera’s USB-C.
The sensor has multi leaf blade protective shutter that auto covers sensor when switched off/changing lens to stop dust and dirt on naked sensor.
The Z9 will have car autofocus in addition to animal and people AF as well as low light -7 EV.
Improved 3D tracking.
Improved articulated screen that even works in portrait mode – it is a completely new design.
New style locking flap for the two CFExpress memory cards.
Third joystick/selector added to use whilst camera close face and shooting.
Many new menu features to tweak and match your shooting style.
The shutter release sound level can be adjusted from silent to loud… so you can still get that D6 machine gun sound…
The official announcement is expected in the next 2 months, but do not expect many cameras to ship before the end of the year. Because of part shortage, the waiting time for the Z9 is expected to be very long.
En odottaisi ihmeitä. Tuokin listaus kertoo sen tason himmelistä että menee n. 3 vuotta että saadaan vakaa firmis. A1 meni jo ohi ajat sitten.
Jos sähkösulkimen volyymille o pitäny tehdä jonneasetus (n. 100dB), ollaan metsässä. Vakuuttavin asia tuossa oli toi erillinen pölysuoja. Siitäkin tosin tulee raporttia että se jää joskus kiinni vaikka virrat on päällä ja lasi vaihdettu. Piraattilinsseillä firmis varmaan tahallaan sulkee sen.
Maffer kirjoitti: ↑Elo 11, 2021 13 : 56
Ei kai tollasia kukaan ole raportoinut :D Ne oli vaan mun ennustuksia miten homma menee RTM-versiolla firmis V1.0:lla.
Kas, negatiivisia ennustuksia, kuka olisi osannut ennustaa ;-)
Eipä nuo kilpailijoidenkaan RTM-versiot ole kovin ruusuisesti lähteneet. Nikonille tämä on aivan uusi malli ton stacked-CMOS kennon kannalta. Mut kuin aina tarttee keksiä joku näennäinen AF-kikka? Car AF? Miksei vain laiteta kamera tarkentamaan sinne minne katsoo?
Toivottavasti Nikon onnistuu tämän kanssa riittävän hyvin. Pysyisi edes jonkinlainen kilpailu valmistajien välillä eikä kameroista tulisi vain Sonyn ja Canonin mittelöä.
Paineet saada tämä markkinoille nopeasti on luultavasti niin suuret, että bugeja tulee varmasti löytymään julkaisun jälkeen. Sellaista kameraa tuskin enää nähdään, mikä mensisi vielä vuoden päästä v1.0 softassa.
No siitä päästään taas siihen miksi peilittömät o niin kivoi - EVF. DSLR toimii ihan jees jo takatöllöllä ja jos prosuissa olisi tarpeeksi puhtia, pelkkä liveview riittäisi edelleen kaikkeen eikä peilittömiä tarvisi mihinkään.
Miten toi Car AF muuten toimii konseptina? Jos kinolla kuvaa vaikka 200/2.8 kakkulalla 4m pitkää autoa, niin siinä o aikamoinen määrä tuhnua autossa ja muutama kymmenen senttiä terävää mikäli läheltä ottaa. Himmentämällä ja pannaamalla toki helpompaa. Yrittääkö Car AF osua kuskiin vai etulyhtyihin?
AnHa kirjoitti: ↑Syys 14, 2021 21 : 35
Onko tuota sisäänrakennettua GPS:ää jossain toisessa kamerassa? Hyödyllinen ominaisuus. Näen sillä paljon arvoa.
Olympus OM-D E-M1X, joka tallentaa sijainnin lisäksi myös lämpötilan, ilmanpaineen ja kuvan kompassisuunnan.
Ihan hyvä. Vähän kuin pentax K-1:ssä, kääntyvä näyttö. Paras ratkaisu, ellei ole tarvetta selfie tyyppiseen kääntöön. Tämän luokan kameraa tosin ei ole tehty selfie kuvaamiseen :-)
